Nick Sidlaruk Posted September 7, 2013 Report Share Posted September 7, 2013 I am building some adjustable shelves and was wondering if I will run into a problem down the road if the pins for the shelves are "loose" in the holes? By lose I mean the pin is .24" dia and the hole is .25". Quote Link to comment Share on other sites More sharing options...
dcustoms Posted September 7, 2013 Report Share Posted September 7, 2013 Depends on the style of pin how much weight will be on the shelves. My gut tells me you will be just fine. I am assuming that your bought 1/4" shelf pins and measured the diameter? Quote Link to comment Share on other sites More sharing options...
Trip Posted September 7, 2013 Report Share Posted September 7, 2013 ==> By lose I mean the pin is .24" dia and the hole is .25" The primary reason folks end-up with 'lose' pins is poor drilling technique. If you've never drilled shelf pin sockets, practice on some scrap, get yourself a jig, etc and test the fit for yourself. If you are really worried, Rockler, Lee Valley, etc sell pins with socket inserts that guarantee a snug fit. Quote Link to comment Share on other sites More sharing options...
Nick Sidlaruk Posted September 7, 2013 Author Report Share Posted September 7, 2013 Here is the link to the pins they are calling them "spoon shaped" http://woodworker.com/brass-support-w-14-pin-mssu-867-365.asp?search=14%20shelf%20pin&searchmode=2. Yes you are assuming correctly. Quote Link to comment Share on other sites More sharing options...
rodger. Posted September 7, 2013 Report Share Posted September 7, 2013 You could always drill the hole a bit larger and use a bushing if you are concerned. Then the pin fits perfectly in the bushing. I like the spoon style pins, I use them all the time. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted September 7, 2013 Report Share Posted September 7, 2013 I find that the finish improves the fit. Not trying to finish the inside of the holes but the finish soaking into the wood swells the fibers slightly and then makes them stiffer when it dries. Do a test you might be surprised . Sometimes I have to take a Q-tip and stain the inside of the holes when really light wood and a rich stain color might be distracting in a display case. Have you checked your drill bit? Some cheap bits are not exact in size. Or try a slightly undersized bit. Metric or machinest lettered and numbered bits might come close. And usually once a shelf and load is on the pins they stay in place just fine. I use the smallest of the stick on clear bumpers on the spoon pins with glass shelves. 1 Quote Link to comment Share on other sites More sharing options...
Tpt life Posted September 7, 2013 Report Share Posted September 7, 2013 Steve has a point worth mentioning. Most pins are milled overseas these days in metric shops. The 1/4" is often an approximation. Quote Link to comment Share on other sites More sharing options...
Nick Sidlaruk Posted September 7, 2013 Author Report Share Posted September 7, 2013 Thanks guys for the all the info.This is a budget build so pin sleeves are out. I will try putting some shellac in the holes on my test piece and see if that doesn't snug up the fit. I am working with melamine so finishing it like Steve mentions is out. The bit is spot on .25" and the pins are .24". I am using peg board as my hole guide, so I am stuck to 1/4" dia. bits unless there is a trick that I am missing. Quote Link to comment Share on other sites More sharing options...
Rapid Roger Posted September 7, 2013 Report Share Posted September 7, 2013 I use the "L" style usually but, looking at the "spoon" style, I think they will work the same way....The shelf itself will lock the pins in place and trap them from falling out. Rog Quote Link to comment Share on other sites More sharing options...
Trip Posted September 7, 2013 Report Share Posted September 7, 2013 Here is a link to 'spoon' style pins with insert socket sleeves. I used these on a home theater cabinet. The 'sleeves' improve the support normally offered by these type of pins... http://www.rockler.com/product.cfm?page=946&site=ROCKLER 1 Quote Link to comment Share on other sites More sharing options...
wdwerker Posted September 7, 2013 Report Share Posted September 7, 2013 To improve your quality of holes and alignment try taking a new strip of pegboard and a strip of some hardwood like maple. Use your drill press to drill the maple so you have a guide that keeps your holes really straight. Crooked holes can lead to wobbly shelves . If you end up with misaligned holes sometimes putting one spoon pin in upside down will cure it. Another fix is to wrap clear tape around the spoon until it is big enough to make up the difference. Quote Link to comment Share on other sites More sharing options...
dwacker Posted September 7, 2013 Report Share Posted September 7, 2013 Router bits and end mills usually cut the nicest holes for shelf pins Quote Link to comment Share on other sites More sharing options...
Dave H Posted September 7, 2013 Report Share Posted September 7, 2013 +1 on router bits, I made a simple jig out of plywood, drilled 1/2" holes on 1" centers 1" from both sides of the plywood jig(so the jig is the same for whatever side of case you are working on) using a 1/2" guide bushing and a 1/4" router bit I clamp jig to the side I'm working on once I've bored the holes on one side move jig to other side, rinse repeat. you'll need a plunge router for this method it's fast and repeatable and, accurate as your jig is accurate. Quote Link to comment Share on other sites More sharing options...
G S Haydon Posted September 7, 2013 Report Share Posted September 7, 2013 Here is a link to 'spoon' style pins with insert socket sleeves. I used these on a home theater cabinet. The 'sleeves' improve the support normally offered by these type of pins... http://www.rockler.com/product.cfm?page=946&site=ROCKLER +1 to this, we nearly always use the sleeves. Quote Link to comment Share on other sites More sharing options...
davestanton Posted September 8, 2013 Report Share Posted September 8, 2013 I did a quick video on the kreg shelf pin jig if you are interested. http://www.youtube.com/watch?v=JX4rJkQMC-Y Quote Link to comment Share on other sites More sharing options...
