duckkisser Posted June 24, 2011 Report Share Posted June 24, 2011 So miters are hard to get right any tips on decent filling of the miter crack that blends into finish coat and wont look discolored. Quote Link to comment Share on other sites More sharing options...
TimV Posted June 24, 2011 Report Share Posted June 24, 2011 If you're talking about the outside edge of a mitre, I like to use a burnisher to roll the edge over so the gap closes. On the faces, god forbid I have gaps there, I will put a drop of yellow glue on the gap then sand around to fill it with dust. Tim Quote Link to comment Share on other sites More sharing options...
TheNehlsEnd Posted June 24, 2011 Report Share Posted June 24, 2011 If the pieces aren't attached yet sometimes you can tighten the gap by making a saw kerf in the joint. Otherwise sawdust mixed with glue make a good filler. Quote Link to comment Share on other sites More sharing options...
duckkisser Posted June 24, 2011 Author Report Share Posted June 24, 2011 If the pieces aren't attached yet sometimes you can tighten the gap by making a saw kerf in the joint. Otherwise sawdust mixed with glue make a good filler. yep done all that just wish that i was experienced enought to get them perfect everytime........ugggg always seem to be a little off Quote Link to comment Share on other sites More sharing options...
jonny transcend Posted June 26, 2011 Report Share Posted June 26, 2011 Just practice and you will get them. Do not settle for filling those gaps! Quote Link to comment Share on other sites More sharing options...
ChetlovesMer Posted June 27, 2011 Report Share Posted June 27, 2011 I generally fill my gaps with tears. It doesn't help hide it or anything, but I find the more expensive or rare the wood used, then the more tears it requires. Quote Link to comment Share on other sites More sharing options...
