DadoHead Posted September 5, 2011 Report Share Posted September 5, 2011 I used poplar, and plan on painting it to match my kitchen cabinets (I have a door that someone screwed a towel rack on the back of the door where the screws went through to the front). Also, I plan on putting a ogee edge on the perimeter once I get the right bit. I bought a face frame hidden hinge and a forstner bit to cut the recess. I don't have a drill press right now. Is it advisable to cut these recesses without a drill press, or is this a good time to invest in one? Thanks! Quote Link to comment Share on other sites More sharing options...
jasonjarrard Posted September 6, 2011 Report Share Posted September 6, 2011 great job! i did my first one a few months ago. so i know how proud you must feel. p.s. yours looks better than mine Quote Link to comment Share on other sites More sharing options...
DadoHead Posted September 6, 2011 Author Report Share Posted September 6, 2011 Thanks for the compliment! I have learned so much from this forum and Marc. Quote Link to comment Share on other sites More sharing options...
Nick2cd Posted September 6, 2011 Report Share Posted September 6, 2011 that looks great! good work! Quote Link to comment Share on other sites More sharing options...
Jerry_in_SD Posted September 6, 2011 Report Share Posted September 6, 2011 You can purchase a jig to drill the 35mm cup hole using a hand held drill from Rockler. It registers the hole the proper distance from the door edge and the holder for the fostner bit limits depth to the right depth. That said if you mark the centerpoint carefully and creep up on the depth, you may be able to do it freehand. do some practice first. Especially if you are only doing one door. I use the Rockler jig even though I have a drill press. Just easier to use. Quote Link to comment Share on other sites More sharing options...
Woodog Posted September 14, 2011 Report Share Posted September 14, 2011 nice job looks good. Quote Link to comment Share on other sites More sharing options...
