Brian Tracey Posted October 4, 2011 Report Share Posted October 4, 2011 I watched the Rocking horse build on the podcast and found a product that will really make removing the paper patterns that are applied to the wood much easier. It's a Scotch brand product found in arts supply stores called "Spray Mount / Repositionable Adhesive" ( it comes in 4oz. or 10.25oz spray cans) You just spray it onto the back of the paper, let it dry for one minute and then simply place it onto your wood. Roll or press out any trapped air bubbles and your done with the application process. To remove just peel it off and the adhesive stays completely on the paper. It's kind of like sticky notes on steroids. Try it, you'll like it! Brian 2 Quote Link to comment Share on other sites More sharing options...
duckkisser Posted October 4, 2011 Report Share Posted October 4, 2011 ya i have used it to seal and attach pastel chalk to paper works decent but hair sprays works as well and its much cheaper. might want to try it ona scrap wood and see if it will attach it to wood. Quote Link to comment Share on other sites More sharing options...
rmac Posted October 4, 2011 Report Share Posted October 4, 2011 Hey, thanks for this tip. I've been using 3M 77 spray adhesive and it's awfully aggressive for attaching templates. -- Russ Quote Link to comment Share on other sites More sharing options...
duckkisser Posted October 4, 2011 Report Share Posted October 4, 2011 Hey, thanks for this tip. I've been using 3M 77 spray adhesive and it's awfully aggressive for attaching templates. -- Russ not shure who you talking to but if its me i havent tried this with attaching templates only on attaching drawing medium onto paper so if it works on wood let me know. Quote Link to comment Share on other sites More sharing options...
rmac Posted October 4, 2011 Report Share Posted October 4, 2011 not shure who you talking to Well, I was talking to briant. Somehow I doubt if hair spray would work like a sticky note. But I've been wrong before! -- Russ Quote Link to comment Share on other sites More sharing options...
Brian Tracey Posted October 4, 2011 Author Report Share Posted October 4, 2011 I guess I was trying to let everyone know about a product that works. I was watching The latest Woodwhisperer Rocking Horse podcast where Mark had to scrape and sand off the paper template after it served it's purpose. This Scotch "Spray Mount" product works very well when applying paper to wood. Just as described in the original post. The second picture shows the paper attached to the wood and the third shows how the paper comes off clean with the adhesive only on the paper. It's very much like a very strong Post-It note. Brian 1 Quote Link to comment Share on other sites More sharing options...
duckkisser Posted October 4, 2011 Report Share Posted October 4, 2011 glad it works so well i just like the idea of going to the kitchen or bathroom and making my own stuff. Quote Link to comment Share on other sites More sharing options...
mds2 Posted October 4, 2011 Report Share Posted October 4, 2011 Thanks, I've been looking for a product like this. I've been cutting a lot of "craft" stuff out if plywood lately and this sounds perfect for what I'm doing. I'll keep an eye out for it. Quote Link to comment Share on other sites More sharing options...
chicks82 Posted October 4, 2011 Report Share Posted October 4, 2011 I watched the Rocking horse build on the podcast and found a product that will really make removing the paper patterns that are applied to the wood much easier. It's a Scotch brand product found in arts supply stores called "Spray Mount / Repositionable Adhesive" ( it comes in 4oz. or 10.25oz spray cans) You just spray it onto the back of the paper, let it dry for one minute and then simply place it onto your wood. Roll or press out any trapped air bubbles and your done with the application process. To remove just peel it off and the adhesive stays completely on the paper. It's kind of like sticky notes on steroids. Try it, you'll like it! Brian This is awesome thank you for the tip. I use a lot of paper templates and have used many different things my current method is standard Elmer's glue stick really easy and just a simple wet brush gets the pattern off along with the glue. The thing i like most about the product you a talking about is that it looks like i will be able to reuse templates. Quote Link to comment Share on other sites More sharing options...
fuzzypirate Posted October 12, 2011 Report Share Posted October 12, 2011 My wife and i make a lot of garden cutouts of giant bugs, critters, etc. I am just starting to get into more complex furniture builds, but I like to reuse my paper templates so I have always used large sheets of tracing paper and trace the patterns out onto my material. The lines hold up well enough for cutting and assembly and then sand off easily in finishing. Quote Link to comment Share on other sites More sharing options...
duckkisser Posted October 12, 2011 Report Share Posted October 12, 2011 instead of tracing paper get the big rolls of news print much cheaper get the end rolls from newspaper Quote Link to comment Share on other sites More sharing options...
wilburpan Posted October 12, 2011 Report Share Posted October 12, 2011 That's an awesome tip. Thanks! Have you tried this with sandpaper on glass/granite for sharpening? Quote Link to comment Share on other sites More sharing options...
r_vanderlinden Posted October 12, 2011 Report Share Posted October 12, 2011 Both Elmers and 3M make repositional glue sticks that work great and leave little to no residue. I've also used standard rubber cement. Quote Link to comment Share on other sites More sharing options...
dwacker Posted October 12, 2011 Report Share Posted October 12, 2011 FYI you can do pattern transfer with any laser printed image. Lay it face down on the wood and Iron it on high with a household iron and the image will transfer to the wood. Don Quote Link to comment Share on other sites More sharing options...
duckkisser Posted October 12, 2011 Report Share Posted October 12, 2011 i have tried that dwacker some printing ink works better then others. shoot if its small i just use carbon paper if its big then i glue it on. Quote Link to comment Share on other sites More sharing options...
Brian Tracey Posted October 15, 2011 Author Report Share Posted October 15, 2011 Wilbur Pan, I have used the "Spray Mount" to adhere wet/dry sandpaper to my granite sharpening bench, and it works great. After removing the wet/dry sheets, I found that there was almost no adhesive left on the granite and the very small amount that i could feel came right off with either mineral spirits or denatured alcohol. I used three sheets in a row to lapp a plane base and it worked great. The sheets were removed and then repositioned and never moved. Brian Quote Link to comment Share on other sites More sharing options...
areynoldsre Posted October 15, 2011 Report Share Posted October 15, 2011 Use 3M 77 all the time for attaching patterns for scroll saw work - works well. Be careful how much you use and how long you let it stay on the wood. Sometimes it can take a lot of sanding to get it off if you leave down too long. Last week I try first putting down a layer of blue tape over the wood and the glued the pattern to the tape. Clean up was snap after that. 1 Quote Link to comment Share on other sites More sharing options...
jHop Posted October 17, 2011 Report Share Posted October 17, 2011 My dad swears by using the lighter fluid refills (for Zippo type lighters) to remove residue from price tags from books and other items. Think this will have an effect on the wood (other than the obvious flammable worry)? (By the way, I've tried it on a couple things. You don't have to flood the surface, but drizzle a little around the edge of the sticker / tag until the tag soaks up the fluid. Then simply scrape with a knife blade or razor blade. Most of the glue residue comes up with the tag. Sometimes, the tag rips in an odd location from the "water line." Just reapply the fluid, and let it sit a little longer. There have been only a handful of times I've had to really pour a lot of fluid on a tag, but I don't remember if those were on wood or ceramic...) Quote Link to comment Share on other sites More sharing options...
duckkisser Posted October 17, 2011 Report Share Posted October 17, 2011 rubing alchole works as well Quote Link to comment Share on other sites More sharing options...
junebug Posted October 17, 2011 Report Share Posted October 17, 2011 My dad swears by using the lighter fluid refills (for Zippo ™ type lighters) to remove residue from price tags from books and other items. Think this will have an effect on the wood (other than the obvious flammable worry)? (By the way, I've tried it on a couple things. You don't have to flood the surface, but drizzle a little around the edge of the sticker / tag until the tag soaks up the fluid. Then simply scrape with a knife blade or razor blade. Most of the glue residue comes up with the tag. Sometimes, the tag rips in an odd location from the "water line." Just reapply the fluid, and let it sit a little longer. There have been only a handful of times I've had to really pour a lot of fluid on a tag, but I don't remember if those were on wood or ceramic...) I've heard of guys using naphtha (lighter fluid) to wipe down a section of wood to see what a finished piece will look like. Naphtha is good for removing adhesive and waxy substances from wood. Just make sure to use it in a well ventilated area Quote Link to comment Share on other sites More sharing options...
duckkisser Posted October 17, 2011 Report Share Posted October 17, 2011 I've heard of guys using naphtha (lighter fluid) to wipe down a section of wood to see what a finished piece will look like. Naphtha is good for removing adhesive and waxy substances from wood. Just make sure to use it in a well ventilated area and while not smoking. Quote Link to comment Share on other sites More sharing options...
stlchrisosu Posted October 18, 2011 Report Share Posted October 18, 2011 Love the idea of the spray mount. I also watched the rocking horse build, and wanted to build something like that for my niece. Her room is decorated with turtles, so I found a turtle rocking chair to build for her. I got the pattern in the mail on a large sheet of paper, but I got to thinking what if I want to build this again another time in the future for somebody else? I'd like to keep the pattern for another time, so Marc's instructions of sanding off the paper will not work for me. Will the spray mount be a good idea, or should I go a different route? Any suggestions would be awesome!!! Sorry if this sounds like a noob question, but I've never done anything transferring patterns before. Lately all I've been doing is building poker tables and backyard decks for family and friends. Quote Link to comment Share on other sites More sharing options...
Rapid Roger Posted October 18, 2011 Report Share Posted October 18, 2011 stichrisosu, No, the spray glue will ruin your paper pattern also. You need to glue the paper to "hardboard", "cardboard", or "thin plywood" to make a permanent pattern. You then cut around that and trace around the hard pattern onto the wood for the turtle. So that way the pattern can be reused again. Rog Quote Link to comment Share on other sites More sharing options...
jHop Posted October 18, 2011 Report Share Posted October 18, 2011 stichrisosu, No, the spray glue will ruin your paper pattern also. You need to glue the paper to "hardboard", "cardboard", or "thin plywood" to make a permanent pattern. You then cut around that and trace around the hard pattern onto the wood for the turtle. So that way the pattern can be reused again. Rog Don't forget plexiglass or acrylic, or poster board, or even foam board. I haven't used the latter two, but I do have a few semi-flexible tracing patterns I use for leatherwork. (these were manufactured, meaning I did not make these, but I know the material is available to purchase ... somewhere.) These sheets are barely a sixteenth of an inch thick at best. Quote Link to comment Share on other sites More sharing options...
Beechwood Chip Posted October 18, 2011 Report Share Posted October 18, 2011 If you use something 1/4" and rigid, then you can jig saw outside the line and use a router with a pattern bit or flush trim bit to clean up the piece. Quote Link to comment Share on other sites More sharing options...
