ddean5 Posted October 27, 2011 Report Share Posted October 27, 2011 I have flatten the face of the board, then when I joint the edge with the flat face against the fence, my edge has become trapezoid (front width smaller then the tail width). Is the problem with my technique or is there a jointer adjustment incorrect? Please Help! Quote Link to comment Share on other sites More sharing options...
dwacker Posted October 27, 2011 Report Share Posted October 27, 2011 More likely your technique or a short bed. Push down on the back of the board until the front has a long enough flat spot to guide the cut. I cant really explain it very well. There is a video on new woodworker .com that explains it fairly well. Don Quote Link to comment Share on other sites More sharing options...
TimV Posted October 27, 2011 Report Share Posted October 27, 2011 Make sure your fence is square to the table along its full length, use a good quality square. And, verify that you are actually holding the work piece against the fence and not the edge along the table. And finally, which is more work, verify that your blades are parallel with the table bed along their full width of cut. Quote Link to comment Share on other sites More sharing options...
Darnell Hagen Posted October 27, 2011 Report Share Posted October 27, 2011 If your outfeed table is drooping you'll lift the trailing corner, taking more and more off the front. Your knives could be higher than the outfeed, too, but this is less likely. Try repostioning your fence, sometimes it's only one corner that's droopy. If you can get a straight edge at a different point on the table you can buy yourself some time until you're able to do the adjustment. Quote Link to comment Share on other sites More sharing options...
ddean5 Posted October 28, 2011 Author Report Share Posted October 28, 2011 Thanks guys! I found the out feed table was not level with the knifes (higher then knifes). Quote Link to comment Share on other sites More sharing options...
Skunkeye Posted October 28, 2011 Report Share Posted October 28, 2011 If you are jointing the face and then one edge the board is likely to be trapezoidal until you make the width parallel over the length of the board by trimming the non-jointed edge on the table saw. If it is the thickness that isn't consistent, you have to make sure you are thickness planing with the jointed face down. You can't expect anything to be parallel after jointing one face and one edge. If you haven't watched Marc's "The Jointer's Jumping" video (I think number six), I highly recommend it. Quote Link to comment Share on other sites More sharing options...
