FrenchysFroth Posted January 21, 2012 Report Share Posted January 21, 2012 I've been following along with Marks workbench build and decided to go ahead with a long anticipated upgrade to my bench. I have a 24 inch by 72 inch red oak butcher block that I use for a bench. I have a makeshift vice on it now but want to replace it with a veritas twin screw end vice and a side vice and put in 3/4" dog holes. I have the vice hardware and the material to buildups oak tressel legs. Here's the problem, the butcher block is 1 3/4" thick and I have read that bench hold fast need 3 to 4 inches to hold properly. I was thinking of flattening the bottom and laminating 4 pieces of 6/4" by 6"oak to the bottom. This would build up the thickness of the bench top to just over 3". Question, if I use similar oak will I have problems with wood movement? Quote Link to comment Share on other sites More sharing options...
kaiser Posted January 22, 2012 Report Share Posted January 22, 2012 That is a good question. If you stagger the glue line from the top laminant and the bottom pieces you are going laminate on, you have a good chance of neutralizing the wood from moving at different rates. Myself, I do not trust a horizontal glue line that will be subjected to that much punishment. You also are laminating wood that has had a chance to dry out far more than the wood you would laminating to it. It is worth a shot, or just use the butcher block that you have for a finishing or assembly table and laminate a new top. Quote Link to comment Share on other sites More sharing options...
FrenchysFroth Posted January 22, 2012 Author Report Share Posted January 22, 2012 Thanks Kaiser, offsetting the glue lines makes a lot of sense. I was actually thinking of using the butcher block for an assembly table and starting from scratch. Thing is, I'm on a very tight shop budget. I already dumped a chunk of change in hardware & material to what I have. I was hoping I can finish up with a couple hundred bucks in the red oak. If I have to go back to square 1 it would be about 3 times that, and a assembly table to add into the pot. Although I'm still considering it I keep telling myself to be resourceful. Would love to hear any other suggestions out there. Quote Link to comment Share on other sites More sharing options...
Barron Posted January 22, 2012 Report Share Posted January 22, 2012 Actually, as I understand it, its that holdfasts start to have issues holding on material much over 3" thick. In Marc's interview with Christopher Schwarz on the Roubo build (4" top) , Schwarz suggested drilling and 1" hole from the bottom up an inch or so, then going with 3/4" on through the top. The holdfast now thinks its in a thinner bench. My current bench isn't much thicker than yours, and I have good luck with them holding. Have you tried one out yet? If they work in what you have it could save time and money. Quote Link to comment Share on other sites More sharing options...
